-   -   What's in a MCM HP425 (https://www.offshoreonly.com/forums/general-q/52975-whats-mcm-hp425.html)
duunoit 06-23-2003 01:57 PM
Does anyone know what Mercury HP did to a 454 in 1992 to make it a HP425? I'm looking to try to build it a little over next winter and don't want to miss anything.
Chris
PatriYacht 06-23-2003 04:29 PM
It's the same as a 420. Square port heads, 4 bolt mains, good 7/16's rods. Crane lists the cam specs on their web site, hydraulic flat tappet. Holley 800 on a Wiend Excellerator manifold. Good reliable engine. Mercury put Gils on these for a year or so and called them 450's.
IRONMAN 06-23-2003 11:23 PM
The 450 had a Hyd. roller cam also.
Griff 06-23-2003 11:45 PM
Stock cam specs for the 420/425
Crane #132561 hydraulic flat tappet
228/236 .530/.551 on a 114 lobe separation
duunoit 06-24-2003 04:40 AM
Compression Ratio
You guys don't know what the compressions ratio is, do you?
David 06-24-2003 05:01 AM
8.8:1
duunoit 06-24-2003 06:54 AM
Supercharger?
That wouldn't be too high to strap a super charger on it, would it?
