-   -   Overfueling (https://www.offshoreonly.com/forums/general-q/53194-overfueling.html)
LLIGHTENING 06-26-2003 08:44 AM
Overfueling
I have a 502 EFI with M1 Procharger on it.
I was running it with plugged valve cover breather tubes.
Subsequently the crank pressurized and the oil pumped out.
After replacing the oil, putting in new plugs and replacing the Map Sensor, the engine still seems to be using an excessive amount of gas.
So much gas that I get a black layer of unburned fuel behind the boat.
Any ideas as to the cause?
blue thunder 06-26-2003 04:22 PM
What temps are you seeing on your water temp gage? Does not seem to me that it would be related to the lack of crankcase ventilation. Feels like a coolant sensor out of range.
BT :cool:
Dixie Doug 06-26-2003 05:00 PM
what's your fuel pressure?
Adivanman 06-26-2003 06:55 PM
fouled injectors?
LLIGHTENING 06-26-2003 07:42 PM
BLUE THUNDER.
I was talking to Mark at Precision Marine and he was of the same opinion , that the temp sensor might be bad.
He also went on to say that the VST tank might have some junk in it causing the last 2 cylinders to receive to much fuel.
Dixie Doug - The Fuel Pressure on the Gage is showing 50 at first ignition and between 40 and 45 when idling.
Dixie Doug 06-27-2003 09:08 AM
Originally posted by LLIGHTENING
BLUE THUNDER.
fuel pressure should be 30-34 @ idle
LLIGHTENING 06-27-2003 09:20 AM
Doug. is this with the ProCharger as well that it should be this low?
Dixie Doug 06-27-2003 09:25 AM
that is according to ProCharger specs
LLIGHTENING 06-27-2003 10:41 AM
Thanks Doug,
I'll set the regs back and try that.
blue thunder 06-27-2003 11:34 AM
Let us know how you make out. I'd think 30% extra pressure would equal to 30% extra fuel and a lot of unburned fuel. Good luck.
BT :cool:
