-   -   Looking for feed back on ProCharged 496HO... (https://www.offshoreonly.com/forums/general-q/53209-looking-feed-back-procharged-496ho.html)
Nordicflame 06-26-2003 11:43 AM
Just curious if anyone has run the 3.5 or 5 lb ProCharger on thier 496HO. If so what type of results and/or issues did you encounter?:D :mad: :D :mad:
Thanks,
Dave
bobby daniels 06-26-2003 05:01 PM
we did one( 5LBS ) had no trouble and the boat ran well ! whipple has a l
killer kit as well but the procharger works well and is a day to install !
Dixie Doug 06-26-2003 05:13 PM
1 Attachment(s)
We did one 5lb Twin engine, fuel pressure issues,we'll have more results after Savannah race .New props got lost in the mail.Ran 250 miles in 1 day, average speed 60 + mph no problem.We sell and or install.
Nordicflame 06-27-2003 08:08 AM
That sounds like a pretty good setup. I know the 5 lb setup uses larger injectors and harness. The 3.5 uses the stock injectors. Do you think these are adequate?
I know they would be fine here at our altitude of 4500+ feet where the 3.5 lbs would make it just a little bit better than sea level. My concern would be injector capacity at sea level.
Thanks,
Dave
