-   -   High rpm miss (https://www.offshoreonly.com/forums/general-q/53319-high-rpm-miss.html)
kathycool 06-28-2003 02:23 PM
High rpm miss
Got a question about a friend's boat.........
'96 454 mag
Engine starts to miss at high rpms after running for awhile ( heating up). Eventually gets to where will only idle...... Not a fuel problem. After it sets for awhile, runs ok for awhile. Defininately sounds like some kind of ignition miss.
Have changed dist. cap, rotor, plugs, wires, coil.....no help.
Ignition module? , bad tach?
Any ideas appreciated.
Thanx, George
CESSNA 06-28-2003 06:11 PM
George sounds like the box is bad !
Griff 06-29-2003 12:31 AM
Since all the basics have been replaced, I would guess that the ignition module is getting hot and going bad. Probably not advancing the timing like it should.
Griff 06-29-2003 12:32 AM
Also check the ground connections on the module.
Waterfoul 06-29-2003 01:00 AM
Could be the coil too. They get hot when run for long periods, especially if they are going bad. Will cause a miss.
BadDog 06-29-2003 06:11 AM
I relocated my ignition module to the transom, just be sure to run a ground to it. Less heat buildup. Mounted to a hot exhaust manifold seems like a bad place for an electronic component.
kathycool 06-29-2003 08:39 AM
The module is the next thing he's gonna swap. I have a spare T-IV , but his was different. It actually has 2 "boxes" bolted next to the distributor that have plugs. One was a GM part, the other was a Nippon!.........T-V?
I tried advancing the timing while running when it started missing, only helped a little. Figured if the "box"was going bad, it was interupting the signal to the dist....??
My thoughts anyway:confused:
Thanx for the input
George
mcollinstn 06-30-2003 12:40 AM
I would have hollered "coil" immediately if I hadn't read that you already had replaced it...
Krumbsnatcher 06-30-2003 10:40 PM
I know this might sound stupid, but do you find any moisture in the distributor, is it a marine distributor? I had some problems similiar to mine and it was somehow getting moisture inside and causing it to miss at high rpms. I replaced the distributor with a Billet MSD and no more problems.
kathycool 07-01-2003 08:57 PM
I looked at the dist. right after we shut it down........it was dry. Also checked the "pickup" inside the dist. for cracks, corrosion, etc. .......everything looked new.
Appreciate all the ideas / input.
Gonna try a new module later this week if weather holds, will let ya know what we find.
Thanx, George.
Mr Gadgets 07-01-2003 09:13 PM
Have you tried to cool down the module? How long does it take to cool down and run better? If you pour some ice water on the module that will cool it down quickly and tell you if the box is the culprit. Remember to shut it down before you pour!! LOL.
That might tell you something.
Good Luck!
