-   -   Painting lower units, gimbles and K - planes... (https://www.offshoreonly.com/forums/general-q/53674-painting-lower-units-gimbles-k-planes.html)
mr_velocity 07-08-2003 07:17 AM
Originally posted by formulaF302
I used imron on mine and it lasted only one season with all the correct prep etc.....so cross that one off your list....
My Imron is going on 8 years without a problem. If it's not prepped correctly it will just peel off in sheets.
formulaF302 07-08-2003 08:59 AM
I've used imron for years on my intake manifolds, exhaust manifolds and even aluminum valve covers etc with no problems at all. Its just under water applications it doesnt hold up on. I left the boat in the water for one season after having it rack stored for the first couple years...and the paint start peeling off the drives after that season in the water. It was fine for the 2 years I had kept it on the rack. I asked the paint shop about it and they said that imron is not rated for constant under water applications for that exact reason.
