Oil temp problem???Need some help.
My oil temp is reading between 230 and 260 at cruise speeds. I think this is a little high. My water temp runs between 125 and 140. It use to be between 110 and 125. I have a Whipple charged 502 mpi. I was going to start by changing the water pump first and then go from there.
I know I don't have a T-stat in with the Whipple on the engine. I could sure use some suggestions on what to check. The next step is to go with a heavy duty oil cooler or something. Any help on this would be appreciated. Thanks, Shawn |
Is that temperature being measured in the oil pan?
Not sure where sender is.
| All times are GMT -5. The time now is 06:10 AM. |
