-   -   Black Transom problem (https://www.offshoreonly.com/forums/general-q/54340-black-transom-problem.html)
N2BOATN 07-13-2003 09:38 PM
My boat has twin 350 mag's efi/mpi with the stock flame arrestors there was a little sooting ,,,,well I thought I would try a K&N , put them on Friday and went to the lake today, and when I crank it up it looks like black dust floating on the water and the transom was really black when I pulled the boat out . Do you think that the ecm's need programing because it is getting more air????? any help or advise in greatly appreciated
MACDAD260 07-13-2003 09:51 PM
Sounds like the K&Ns are restricting the air and causing a richer mixture. Try it without any flame arresters and see what happens. If it runs clean without any flame arresters than you will know that the K&Ns are causing more air restriction than the stockers. Not supposed to, I know, but maybe they are.?
Griff 07-13-2003 10:33 PM
What octane gas are you running????? You should run the LOWEST recommended octane for your engines--87? It will burn more completely with less black residue and give the best performance.
formula31 07-14-2003 03:13 PM
The K&N's I bought for my engines were way too small even thought they were the ones recommended by them. Lost 400 rpm. Like Macdad said, take them off and try again.
