Audio Warning System
Does anyone have any knowledge on Mercruisers audio warning systems? During a day of boating my alarm starts to make noise when I restart my engine after sitting for a while. Oil pressure and water temp. is fine. Any ideas of what else it could be?
Thanks, Rick |
If you have a remote reservoir for your drive that's hooked up to the same buzzer
That's probably it because it's a little low. Thanks
There were at least 3 systems that Merc. used, as I recall. Does it just sound from when you hit the key till your engine is up and running and then shut off? If so, the 7 to 14 sec. delay feature for the oil sender is shot. It it just keeps on sounding, then a wire or sender is grounded. --- Jer
Yeah, while I was writing homan came on. The system with the outdrive oil warning was one of the three I referred to. Hope that's it! I like simple solutions!! --- Jer
No it sounds when I turn on the key then stops when the engine starts and then sounds for awhile then goes off and then when I put it into gear it just sound until I turn off the motor.
Rick |
Yeah I hope so also.
| All times are GMT -5. The time now is 07:03 AM. |
