Prop Question
I have a New 17" Mirage Plus prop. I need to get this prop re-worked if I plan on bieing able to have any use for it...How much can a SS prop be worked up in pitch? Actually the main thing is that the prop has a VERY large diameter. I think if the diameter could be cut down and a inch or two added I could use the thing. Can the diameter be taken down? If the thing can't be worked for me then I'll have to sell it. I just hate to "give" the damn thing away.:(
BH |
changing pitch on stainless
Bad Habit Yes,The pitch can be changed on a stainless 2" up or down,as well as the dia" can be changed .Not sure if you really need to do that though ,I will Be glad to discuss it futher and get all the details from you, so we can decide what you really need done.
Darin /281-580-PROP(7767) |
Yep Darin is right. You can trust him to make the prop help your boat perform. Just have all info ready. weight, size, displacement....all the good stuff. Later, 88
| All times are GMT -5. The time now is 09:47 PM. |
