Valve cover breathers
Do I need to plumb the breather hoses to the flame arestor or can I just put a breather on the valve cover and have a clean look. Do you need the vaccum of the carb to pull the breather fumes into the carb ?
Sounds like a simple question....just do not want any excessive pressure in the crank case. Sheikman |
Just the breathers should work fine. If you don't have baffles in the valve covers, they may drip a little oil though.
| All times are GMT -5. The time now is 02:33 AM. |
