-   -   Heads questions (https://www.offshoreonly.com/forums/general-q/55021-heads-questions.html)
88 MACH 1 07-21-2003 05:10 PM
Heads questions
Been having problems with breaking rocker arm studs, going to replace wth 190,000 ARP studs. Now while trying to find out why they are breaking, other info has come up. Stud gridles? Good, bad? and the lastest info is the use of Inconel valves on the exhaust do to high temperatures. Any opinions? Please let me know, 88
goob 07-22-2003 12:45 AM
What kind of motor? Did you change camshaft? If it is stock rocker arms are the slots in the long enough?
Mike
88 MACH 1 07-22-2003 05:40 AM
not stock roller everything,cam, lifters, rocker arms
formula31 07-22-2003 08:38 AM
I have broken plenty of stock studs. They work fine for a while and then start to let go one after the other. Put the ARP's on, youll be fine.
Dennis Moore 07-22-2003 11:56 AM
Out of alignment?
There is a problem that most people are unaware of with roller rocker arms. If the stud isn't in perfect alignment with the valve stem, the rocker arm will bind when it opens the valve. A roller rocker arm has a ridged rocking fulcrom (the needle bearings). The good part about the stamped steel rocker arms is that the rocking fulcrom is a ball. It will self align the rocker arm, with the valve if the stud is slightly out of alignment with the valve stem. This is one of the major advantages to a stud and ball style rocker arm system.
Usually the first thing to wear out on roller rockers is the roller that contacts the valve stem tip, and then the valve guides, but in your case I think it is playing hell with your studs. Stiff valve springs don't help the problem either. Check the stud to valve alignment.
Sincerely
Dennis Moore
88 MACH 1 07-22-2003 02:01 PM
Dennis, will the stud girdle help keep everything aligned?
martiniboat 07-22-2003 02:12 PM
..in my Merlin heads
1 Attachment(s)
I run ARP studs, Comp Cams' stainless roller rockers and a stud girdle. I used to break a few stock studs now and then but since doing this upgrade to my 502, haven't experienced a problem.
Later, Brian Kamrath
'trim tab builder extraordinaire'
jdnca1 07-22-2003 03:27 PM
Before messing with stud girdles...pain in the A$$. Buy a set of Jesel shaft rockers and be done with it. ;)
martiniboat 07-22-2003 04:33 PM
Yeah, those Jesel's do look sweet. I went the girdle route because of an excellent deal and I already had the ss roller rockers.
Now this may warrant another thread but, has anyone broken or cracked an aluminum roller rocker whether it be Crane,Sharp or TRW?
88 MACH 1 07-22-2003 06:34 PM
Anyone know a web address for the Jesel shaft rockers? And what are they? New studs or new rockers? Thanks for all the posts, Bob
