Sea water pump?
how does the pulley on the front of the sea water pump come off? I need to replace the oil seals in front and back and tell if its just pressed on or what....Help!
Mine were not pressed on. You remove the bolts and the pully comes right off.
no blots here must be pressed on.
Mine are also bolted.
took some doing but I got it off and the seals out! picked up the new seals on the way home from work. press it back together at lunch tomarrow. Thanks for the help!!
| All times are GMT -5. The time now is 02:15 AM. |
