496 Ho
I have a 2002 Baja 342 Boss with 496 HO's.
The starboard engine is running 300 rpm's slower than the port at WOT. The boat only has 25 hours on it. I ran up each engine one at a time on the hose in the driveway. There is a noticeable difference like it is running on 7 cylinders when I goosed the throttle, it also backfires through the exhaust when bringing back the throttle. I am pulling the spark plugs today to check them. Any ideas? I am thinking ignition problem. As always I appreciate any input or advice. Jeff |
I had a buddy with the same problem on a brand new 496HO. It ended up being just a loose spark plug wire. Could be the same thing.
I pulled all the spark plugs. All of them except for the number 1 cylinder looked good. It was glazed over and looked like that cylinder is running rich. I'm thinking the injector is staying open. Its going to the dealer Monday.
