-   -   procharge owners need advice. (https://www.offshoreonly.com/forums/general-q/55494-procharge-owners-need-advice.html)
26sonic 07-27-2003 09:54 AM
looking to purchase a procharger for my 1998 26 sonic with 502efi. i have added aftermarket exhaust and air cleaner and k+n filter. i can only get 89 octane fuel and found the m1 "sc" @3.5 psi and 570hp and m3 "sc" @5psi and 620 will work . which unit will work best for me with out having to change head gaskets etc. ? do the kits come with everything for the install and no need to add or modify the hardware? do you have to re-prog. the ecm? would it be worth using the bigger intercooler from the m3 and put it on the m1 ?any info would be appreciated.
Pure Energy 07-27-2003 12:04 PM
I would go with the M3 kit. It is a bigger compressor and will generate less heat. Yes you will need the ecm reprogramed. Check with Procharger about the hardware.
Try e-mailing Tomcat. He has designed the intercooler for the Vortec setup and may have some helpful info for you.
Definately change the head gaskets during the install. A little added expense now will save you problems down the road, trust me. You will kick yourself when you are 20 miles up river and have to be towed home! I had to replace mine because they blew. 1 in the middle of the season and the other motor at the begining of the next.
26sonic 07-27-2003 07:25 PM
come on all you pro charger owners ! help me out !
TSNAVE 07-27-2003 07:42 PM
I have an awesome ProCharger setup you need to check out. Please e-mail me [email protected]. It is also listed on ebay...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2425656081
28Eliminator 07-27-2003 08:49 PM
26sonic, You just missed a great deal on a M1 on e-bay.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2424908807
Even if it didn't have everything, the price was good.
Have you considered a whipple? They have a very good complete kit.
cobra marty 07-27-2003 10:50 PM
I think you are splitting hairs. If you don't plan on more in the future, then save the money and get the M1.
Pure Energy 07-28-2003 05:33 AM
Do yourself a favor and don't buy used. I bought a used pair that had "low hrs." and had to replace them after 125 hrs.
HPJunkie 07-29-2003 09:56 PM
If you cant get enough adreniline then get the biggest you can get. Ill take and M-5 if I could find one. Sow often do you work on your boat ? Every winter? you might have the sickness! I Do ! Greg
