-   -   Bravo I lower gears??????? (https://www.offshoreonly.com/forums/general-q/55536-bravo-i-lower-gears.html)
enticer 07-27-2003 09:35 PM
OK.....with Bravo I lower halves. Are there different gear ratios? For example:
A: 1:36 outdrive
B: 1:50 outdrive
Do they both have the same gears in the lowers and the uppers is what makes the gers ratios different?
Or do I have this wrong?
I have a few lower halves (stock) that came off of 1:36's .... So, perspective buyers ask what ratio....are the lowers.......good question.........I thought they were the same
WILDTHING TAZ 07-28-2003 08:57 PM
NO 1.50 & 1.36 HAVE TOTALY DIFFERENT TOOTH COUNTS ,UPPER AND LOWER
Mbam 07-28-2003 09:42 PM
Taz, not true. Not trying to be argumentative, but regular or XZ B1 changes ratio in the upper (3 choices), only 1 lower gear set.
XR has 1 upper ratio, changes ratio in lower (again 3 choices).
I never did try to work out all the ratios that would be available with stock upper and XR lower gears.
RhinoX 09-02-2003 03:55 AM
you are correct, LOWER ratio is changed on XR
gear count
1.5 = 15/19
1.35 = 15/17
1.26 = 17/18
with standard straight cut XR 16/19 upper gears
many combinations possible with different XZ upper gears
Dennis Moore 09-02-2003 10:16 AM
All Bravo One Gasoline lower gearcases have the same gears. Bravo XR and diesel have different gears.
