-   -   OK Guys I Need Oil Temp Help (https://www.offshoreonly.com/forums/general-q/56785-ok-guys-i-need-oil-temp-help.html)
5150FORCE29 08-12-2003 06:03 PM
I have a 540 NA 650HP Engine that is cooled throught a big oil cooler which also runs my power steering through the cooler as well.
The oil temp runs real cold like(160-190's) until I get up to about 80MPH or 5000 RPM range.
Oil temp will jump to 260 in a hurry, Then I have to chill back down to 3-4K rpm range to let it cool. What do you guys think the reason is for the oil temp jump, Is my standard bravo 1 water pick up not picking up enough water to cool at high speeds.
Others I have talked to say there 540's run the same, some say they run about 230 at WOT. I frustrated, what do you guys suggest. Add another cooler maybe?
DanB 08-12-2003 06:29 PM
Were are you taking the temp? Pan, Block, before or after the cooler?
5150FORCE29 08-13-2003 09:30 AM
I ment to check where my temp sender was my last trip out, Not sure at this time, Running straight 50wt Racing Valvoline
mopower 08-13-2003 05:49 PM
Re: OK Guys I Need Oil Temp Help
It sounds as though this is a 330hp version that maounts along side the oil pan (with the ps cooler in it too)
I have HP500 style on my 540's that mount sideways above the bell housing. These are larger than the combo. units and then I have a separate ps cooler along side the oil pan I rarely see 200*
