-   -   what should the compression be? (https://www.offshoreonly.com/forums/general-q/58803-what-should-compression.html)
hauling ass-a 09-09-2003 06:30 AM
how many pounds should i have for a stock 2000 502 mag?
Biggus 09-09-2003 06:47 AM
@155
hauling ass-a 09-09-2003 07:40 AM
did a test last night and came up with 120 should i rip out my hair?
cuda 09-09-2003 07:42 AM
Did you have all the plugs out, the throttle open, and a fully charged battery?
220BR 09-09-2003 08:10 AM
Merc has a service bulletin on doing a compression test on their engines.
hauling ass-a 09-09-2003 08:51 AM
the throttle was at idle position, batteries charged, but did not pull all plugs. Anything else would be appreciated guys.
cuda 09-09-2003 09:23 AM
Pull all the plugs and open the throttle, I'm sure your compression will be fine.
stevejohns 09-09-2003 04:05 PM
I used a cheapo tester and had reading of 90-110. Took it to a proper mechanic , his tester read 147-153 on a motor with 220 hours on it at 1800 feet alt. FYI alt will affect the numbers. sj
