Intercooler Repair
Are Superchiller cores repairable or do you need to just replace them. Mine has a very slight (lost 3lbs. in 2+ hours) Didn't even realize it was leaking until I saw a very slight puddle. Should I risk trying a stop leak of some sort?
Thanks for your input. |
I believe the general concensus is cores aren't really repairable. If you manage to do jerry rig repair in one t very questionable on weathe rot run it or not. After all if it started leaking badly it could cause your engine to grenade,
| All times are GMT -5. The time now is 08:08 PM. |
