Prop for hole shot
My current 19p will spin 5200+. Will a 19p 21p or 23p give you the best hole shot. I do understand proping and rpm on the high end. What pitch will give you the most bite comming out of the hole. Is more pitch better?
thanks |
FF,
No, the 19 will do the most for your hole shot . Also four blades usually help coming out of the water too |
remember the more out of the hole the more top end you lose .the merc. high five gives the best hole shot that i have found yet .what drive do you have ?
Thanks,
I have a vortec 355 with an airgap intake, 4 barrel turning an alpha I gen 2 and it jumps up on plane. I know I can turn a bigger prop on the high end but I love the hole shot for water skiing. On my high end I can only get 50 from the boat when it is light. With a 21p I could probally add 2 knots and turn 5k or a 23p add 4 knots and turn 4800. Most of the time we do watersports and maybe the 19p that gives me the best hole shot is also the easiest on the motor. Maybe I won't stretch my rods again with the 19p. No knocks is a good thing. Thanks |
| All times are GMT -5. The time now is 06:25 PM. |
