-   -   By-passing water around tailpipes? (https://www.offshoreonly.com/forums/general-q/60098-passing-water-around-tailpipes.html)
John B 09-25-2003 07:49 PM
Has anyone tried this? How and how much water? What were the results? I have about 18 inches of rubber exhaust hose after the tailpipes, so I will need some water. The mufflers are CMI's.
Thanks, John B
puder 09-25-2003 08:09 PM
i tired no water. melted/burned the rubber hose in about 2 minutes. Though i puked my engine turne dout it was just a rubber fire somming out of my tailpipes....
currently have new metal pipe frmo teh headers out eth transom. The water for them tailpipes only is fed from eth bravo water pickup. SO it only gets h20 at speed. Loud at **** aourn deth docks. Overall its doesn't heat too much idling around and when running there is enough to keep the tails cool. But i am told from behind it looks like a massive "mist" sprayer. Doen;t pour out really. WOrk just fine and reversion isn;t even close to an issue.
John B 09-25-2003 09:43 PM
Puder, thanks for the info. I think your arthritis is getting worst. Good Luck, JB
puder 09-25-2003 11:55 PM
carpal tunnel....
i've beenworkign my ass off on a big project for a client. It will continue to worsen over the next week too. as I have another large project.
jspeeddemon 09-26-2003 07:03 AM
Try putting valve on your hoses to your exhaust and tee the water to a dump so you keep it flowing well, it will make a big difference in the amount of water and loudness, little to none on power that you will notice.
puder 09-26-2003 02:10 PM
cutting back on h20 flow is usefull if you're worried about reversion though.
