How to winterize A/C?
This is the first time that I have had a/c in a boat. What's the best way to winterize it?
I had someone tell me to: -close the sea cock -open up the sea strainer -poor the antifreeze in the sea strainer -turn it on real quick Is this a good way to do it? |
I have a bronze tee in the line from the seacock to the strainer. I close the strainer, unscrew the plug in the tee and screw in a hose barb connected to a length of garden hose. I suck a 50/50 mix of -50 pink antifreeze and water out of a bucket until pink runs out of all 3 discharge fittings.
I've also got similar setups for my genset and engines (won't work on freshwater-cooled motors, only closed cooling motors). Don't use automotive antifreeze. If your strainer has a polycarbonate jar on it, the antifreeze will make it brittle. Even if yours is glass, there are fittings in the loop that automotive antifreeze is hard on. If you have a "pumpout box" in the bilge to take care of the condensation fro the pan, you should also pour some of the mix into it... |
I have a T in mine too, with a garden hose connector, I used compressed air. Then a little antifreeze.
Thanks for your replies. We took the lid off the sea strainer and my buddy poured antifreez (the pink stuff) in the sea strainer while I turned the a/c on. We ran it until I saw the pink stuff coming out the drain hole on the side of the boat.
Do you guys think that was good enough? |
yes that is fine.
BN,
Been doing mine that way for years. Remember to do your FW system the same way...remember that head also bro! |
| All times are GMT -5. The time now is 10:16 AM. |
