-   -   HP engine mounts (https://www.offshoreonly.com/forums/general-q/60273-hp-engine-mounts.html)
GO4BROKE 09-29-2003 06:38 AM
HP engine mounts
1 Attachment(s)
Are stock style solid mounts as good as offshore mounts? It would be a ton of work to convert my aluminum L angles to accomodate offshore mounts, I was thinking these solid mounts would save a lot of work.
Raypanic 09-29-2003 08:37 AM
Offshore mounts give extra strength to the hull as well. They don't go out of alignment unless the boat bends or something. There are some out there (I think Gil) that use the same mounting as above but also offer the "cross Bar" for the added strength. I know "Scott" re-mounted his on his PQ This way
Cord 09-29-2003 09:58 AM
I used the Eddie Marine mounts on my boat. I have a experienced some movement in the mounts, but I havn't bothered to trace the source down.
Scott 09-29-2003 11:21 AM
The solid mounts I installed still have a stud that the motor sits on but it is NOT adjustable the large nut holds the mount down flush and you do not have a adjustable nut under the flange like you have pictured.
I removed my old L brackets and installed new ones so I could drill new mounting holes and filled the old stringer holes.
It sounds like a lot but it was not that big of a deal and now my motors do not move. It had gotten out of hand where I would have to readjust the old mounts (nuts backed off) every few hours. In the beginning when I was not aware of what was going on I actually had a engine break the mounting bolts and it fell over on to a stringer laying on the Alternator bracket:eek:
If it was me I would not even think twice about the little bit of extra work and expense to do it right with solid mounts.:eureka:
SSComp 09-29-2003 04:44 PM
I'd like to go to the offshore style too, especially now that my engines are out (and everything elese for that matter).
Scott what type did you get? How did you get the alignment right?
puder 09-29-2003 11:37 PM
the offshore was a pain in the ass to install but so nice once it was in. teh engein just plopped ina a nd ligned right up.
Scott 09-30-2003 08:21 AM
We used a empty scrap block to do the alignment. I have also heard of guys using plastic blocks. When we put the fully dressed motors back in they lined right up.
With the Gill mounts they function like true offshore mounts but allow you to Take the motors in and by removing one large nut on each side. I have checked it many times and the nut has not backed off or come loose after many hours. I guess with the solid mount and not having the bottom adjusting nut it stays where you put it:cool:
OPIE272 10-08-2003 10:07 AM
How about some links to Offshore motor mount MFG. companies?
I want some but can't seem to find complete assemblies.
DO I HAVE TO "MAKE" THE STRINGER MOUNTS?
Gary Anderson 10-08-2003 10:38 AM
They're available through Merc as a stock item.
4 x 4 x 1/4" aluminum L angle is all thats needed to make the stringer mounts. Just hang the engine in place and bolt up the bell housing to transom plate. Align the motor hanging there. Clamp the aluminum to the stringer and motor mount and drill your holes.
I've never used anything other than the plates to mount a motor. They never move.
Gary
SSComp 10-08-2003 01:48 PM
Gary,
I'm too looking at the stringer mounts. Will the Mercs fit inside my current stringers? Also the back mount looks like it goes between the bell housing anf the block. Will I need to buy a new bell housing that has the starter mounted on the back of the engine?
Gary Anderson 10-08-2003 02:24 PM
I think I've seen dimensions of the plates on a merc parts website. Dont remember where though. BTW, they have both side by side and staggered, make sure you get the right one.
But if they're too big, just cut them off. If too small use 6 x 6 L angle.
As for the rear mount, you usually buy a new bell hosing so the starter (top mounted) and tranny input flange seat fully. Or you can mill the plate thickness off the front of your bell housing. But the only reason I can see to use the rear plate is for a staggered motor using a driveline output. Even SSM drives have tranny tailstocks that ride on the transom plate.
If you want to use a bottom mounted starter, just cut a hole in the plate.
Gary
SSComp 10-09-2003 09:41 AM
Thanks Gary. Lots of helpful info there.
Gary Anderson 10-09-2003 11:57 AM
Found the diagram with dimensions.
Side by side:
http://www.dolleroffshore.com/parts....pn=4269&r=4440
Staggered:
http://www.dolleroffshore.com/parts....pn=4269&r=4441
SSComp 10-16-2003 04:02 PM
It looks like I only have about 21" between the stringers. It also looks like I can take the base Merc front mounts, cut to size and add some strengthening.
I'll let everyone know how it goes!
martiniboat 10-16-2003 09:25 PM
FYI, if you get 'stuck' give me a shout. I'd be happy to help with any custom needs.:cool: Especially the unique stuff.
Sincerely,
Brian Kamrath
