Leakdown tests?
What kind of numbers do you get which show your rings are worn out and need replacement and/ or over bore?
What performance or horsepower loss has anyone seen? Thanks, John B |
Don't think you want more than 10% on any hole and if the rings are going, you should hear air through your breather holes.
HP Loss
John,
I believe you are right. My sources say's at 20% leak down on 4 cylinders you are down maybe 10 - 15 HP per engine. Although this isn't significant, it may be 1 MPH on your top end. Sprague |
| All times are GMT -5. The time now is 09:28 AM. |
