Diff. between RH and LH drives?
I recently purchased a 28 Apache Brave (twin bravo 1's 1:36 gears, 502 carb's). My question which may sound stupid, how can you tell if the Bravo's are RH/LH drives? Is it which way the props turn clockwise/counter clockwise? Stepped up to a twin and looking for speed? Currently running 23' Mirages.
The Bravos, and only the bravos are the same. TRS and Alpha drives are different. They are stamped on the end of the drive shaft LH of RH to tell you what they are. To make a Bravos go the other way you just swap the shifter and they will change dirrection.
Jon |
----yea, what he said...but don't forget to switch the props also..
Audiofn/Celtic Banshee thanks for the reply. This will be beneficial when I jump to larger pitch props.
:D |
Apache, I had the same question and got some great answers to my post in the "Testing and Upgrades" section.
| All times are GMT -5. The time now is 07:33 PM. |
