Bad compression
Hi
I have a 350 Magnum and I made a compression test on it today. Testresult: #1 140 #3 155 #5 140 #7 140 #2 130 #4 30 #6 140 #8 130 As you can se number #4 is bad. What can be wrong?? Please help me to find out whats wrong, where to start |
I would pull the vale cover on that side and check for any valvetrain problems, such as a bent pushrod, broke valvespring are a flat cam lobe, if the valvetrain checks out ok you might be in for a big problem, get a leak down test done on that cylinder to see if you have a burned valve are a dab ring are piston
Could also be a blown head gasket.
Probably a bent valve but put compressed air is the cylinder to find the leak for sure. It will be obvious with that kind of loss.
BT :cool: |
It, more than likely, is a tulipped exhaust valve. Very common. Remove all of the rocker arms and put a straight edge across all of the valve stem tips. I would bet that the exhaust valve stem tip is higher on the cylinder with the low compression. Not a disaster, you will probably only need a new valve and a valve job. Most Mercruiser mechanics do many of them over the years.
Dennis Moore |
| All times are GMT -5. The time now is 04:48 PM. |
