-   -   quick one, torque (https://www.offshoreonly.com/forums/general-q/61629-quick-one-torque.html)
JUSTONCE 10-17-2003 10:33 AM
quick one, torque
Whats the torque specs for gil manifold bolts at the head. 454cu.in.
Thanks,]
Martin.
formula31 10-17-2003 10:43 AM
Way back when I was told 25 ft/lbs and then torque them again after a few cycles. I put considerably more than that on them because I cant get at them later to tighten them up again.
Ratchet 10-17-2003 12:42 PM
See S/M
Look at staibnless marine's website.
They have the install instructions there. I'm sure it's similar for the Gils..............For some reason 25-30 sounds right.
Ratchet 10-17-2003 12:43 PM
Re: See S/M
Originally posted by Ratchet
Look at stainless marine's website.
oops....maybe i should use spell check....
Dennis Moore 10-17-2003 03:15 PM
If you use good gaskets it would be 25-30 foot pounds once. If you use cheap header gaskets (simply punched out of gasket material) you will have the spec memorized in no time (you will change them twice a season).
A three piece gasket, a steel core with gasket material on each side (sandwich steel core gaskets), are the only way to go.
Dennis Moore
Check out my site about gaskets at www.mooreperformance.org
JUSTONCE 10-17-2003 03:38 PM
thanks guys.
formula31 10-17-2003 10:05 PM
DO NOT use a steel core gasket on aluminum headers. Gil sells a real nice graphite gasket that doesnt leak and can be reused and doesnt stick, or use a good felpro or mr gasket performance gasket.
