2 piece timing cover
Does anyone make a 2 piece timing cover for a gen 5 big block. With the 1 piece oil pan gasket, cam changes are a real pain. Thanks.
I've seen several.
All were fairly pricey. Check out Comp Cams... |
Check out the Jesel belt drive.
Thanks, I'll try Comp. Jessel's would be nice but too many $.
PatriYacht
This is directly from the SDPC site: Our 3 piece timing covers are CNC machined from 6061 billet aluminum. The inner ring bolts directly to the block and seals the oil pan. The bottom half of the outer cover contains the crank seal, while the top half can be removed for servicing of the camshaft without removing the balancer. Here is the link http://www.sdpc2000.com/cart.asp?act...art&catid=3114 Bob |
