Aeromotive belt driven fuel pump
Has anyone used the Aeromotive belt-driven fuel pump yet in a marine application? I've used their electric fuel pumps, controllers, and regulators for several years with good results, and I am now considering using their belt driven pump rather than the conventional block mounted pumps.
http://216.242.145.16/products/prod_...-6-1-small.jpg |
We've used our Belt driven pumps on marine race engines for years with great success. The only draw back to running a blet driven pump on a pleasure boat is the fact that you have to run a return line back to the fuel tank. As long as you can get to the tank to get the proper size pickup, and return you will love them. Belt drives are great, if the engine is running you've got fuel not running no fuel. Running an external bypass also lets you play with your fuel pressure settings very quickly.
Doug Schriefer Technical Services Barry Grant, Inc. |
| All times are GMT -5. The time now is 01:52 PM. |
