-   -   pushrods bb-chevy (https://www.offshoreonly.com/forums/general-q/61935-pushrods-bb-chevy.html)
timucin 10-21-2003 04:46 PM
pushrods bb-chevy
is there alternative lenghts for their height?
not talking about tall deck-short deck stuff.
are they all standart length for short deck?
DanB 10-21-2003 05:15 PM
Lots of variables
cam, lifters, deck hgt, rockers, head gasket
They should always be measured
Dan
WILDTHING TAZ 10-21-2003 09:26 PM
i think they are offered in .100 or .050 increment's.comp cams has them all.
jpclear 10-22-2003 02:57 PM
When you start playing games with cams, lifters, heads, and deck heights you must install the test adjustable pushrod and follow the directions supplied therewith to determine the length of pushrods that you must then order.
jpclear 10-22-2003 03:03 PM
When you start playing games with cams, lifters, heads, and deck heights you must install the test adjustable pushrod and follow the directions supplied therewith to determine the length of pushrods that you must then order. YES, SIZE DOES MATTER!! More than .050 off in length and your rocker will not be pushing and rolling or sliding over the center of the valve stem. And that ain't good! --- Jer
