-   -   K&N oil filters, Any good? (https://www.offshoreonly.com/forums/general-q/64461-k-n-oil-filters-any-good.html)
Crazyhorse 11-23-2003 11:56 AM
I've been looking at these because of their high burst pressure. What is the general consensus on them? Any good? Any other recommendations?
traviss 11-23-2003 12:01 PM
Crazy.. I never looked into the K & N ones, But when i needed a high burst filter i went with fram. I use the HP 4... I might be wrong in this but i think you can use the HP 6 on yours...
Whiteknuckle 11-23-2003 02:57 PM
I have been using the K&N"s for some time. I have had no problem with them, but I can't really tell you if they are a good effective filter. After reading some of the lab reports on the Frams I have been staying away from them. My thinking on the K&N is that their other products are very well engineered, and they are very available, so why not?
RedDog382 11-24-2003 03:05 AM
I like using the WIX Racing filters ... high burst pressures, good reviews, great looking, and I think some of the NASCAR guys use them, too. Can be ordered through local WIX suppliers for about $10.00 each.
Vyper340 11-24-2003 06:18 AM
I've used K&N's for some time. No issues other than they cost more than most because of the name. Good features and protection...
audacity 11-24-2003 08:23 AM
use them in the pleasure boat, race boat, car, and the dually diesel! VERY GOOD products.
Cord 11-24-2003 08:41 AM
Why would burst pressure ever be an issue on a boat? True you may plug the bypass, but you'll never run the boat when it's cold out. If you should happen to plug the passage or the filter, it's a moot point because the engine just went south anyways.
Crazyhorse 11-24-2003 05:53 PM
I understand that some filters tend to split at the crimped seam at the top. Even though I don't run the boat in freezing weather it's till possible to have higher-than-normal oil pressure start-up here in the great lakes. I've been reading a little about the K&N filters and just wondered if anyone was running them Cord, you all winterized for the winter?
US1 Fountain 11-24-2003 06:14 PM
Just a thought, wouldn't there be alot of vehicles with burting filters during the winter,(in the states where it actually freezes and snows :) ) if this were a problem?
Crazyhorse 11-24-2003 07:53 PM
All the auto engines have fliter bypass valves so that under those conditions the oil isn't passing through the filter, it just taking the shortcut right into the oil passages.
