-   -   Nordskog GPS Speedometer (https://www.offshoreonly.com/forums/general-q/64474-nordskog-gps-speedometer.html)
StrikinLightnin 11-23-2003 04:46 PM
I recently purchased a Nordskog GPS Digital Speedo.
It's a speedometer only.
The back of the instrument has Intellitronix on it.
I realize that I need to purchase some type of a receiver unit.
Is an antenna considered the complete receiver unit?
If so can I mount it under my Helm?
:confused:
Von Bongo 11-23-2003 06:34 PM
yes, you need the antenna...you may be able to mount it under depending on how thick your dash is. You wire it to the antenna and to power. If I remember you also have to wire the antenna to power too.
You may be able to wire it to an existing GPS unit you have in the boat. You can probably get them cheaper but here is Livorsi prices.
Livorsi
ACCESSORIES
Antenna only for standard size GPS (3 ring terminal) GPSRA $240
Antenna only for Monster size GPS (mole connector) GPSARA $240
