-   -   Procharge 350Mag vs 6.2 (https://www.offshoreonly.com/forums/general-q/64802-procharge-350mag-vs-6-2-a.html)
Whipple Charged 12-02-2003 01:32 AM
The 6.2 is a better motor because it has lower compression and you can run safely 6-8psi vs. 4-5psi on the 350mag. 6.2 will also make about 50-60lbs of torque more at low and mid rpm ranges. Both the 350 and 6.2 could really use a larger capacity oil pan (stock is 4qt) and an oil cooler if supercharging.
Dustin
ontheh2o 12-02-2003 07:58 AM
Thanks for the info! Great forum.
bobl 12-02-2003 09:20 AM
Just for the record the 6.2 uses a forged Lunati 3.75" stoke crank and forged dished pistons to achieve a 9:1 compression ratio. The cam is more aggressive than the 350 Mag. It has the exact same specs as a Crane 104224, but there are no markings on it to identify that Crane made it. It is also internally balanced. Other than that the 2 engines are identical. Ironically, they both use a 2 bolt main block!
Ric232 12-02-2003 08:14 PM
Sometimes you have to just be patient and the guys who really know come out to play (Dustin and bobl).
Thanks.
jafo 12-03-2003 06:19 AM
I confess- I quit playing with pistons engines about 20 years ago--way too many parts trying to beat their way out. I just own and drive them any more.... I'm strictly a turbine guy. :D
But, I'll take a pair of each (but forget the 6.2, I want the Scorps);)
