Surface drives
Ok, I'm not sure I understand surface drives. What is the benefit of converting my bravo one into a surface drive? Can someone help??
increased reliability ASD drives take a crap load of power to break. It willa lso be faster thana bravo and high speed handlign will probably be better if its setup corrected. Negative are low speed handling might not be as good and reverse is kind of crappy on them. DOcking get alittle tiougher BUT if you're killign bravos left and right surface drives are the ****.
ok, thanks a lot
anytime
Arneson has a converstion for the Bravo. Direct bolt on, If someone would like to give me 16g's I'd love to test it out !! I think that it is the way to go.
Go Pulse Drive
Arneson surface drives do require a transmission and probably have to move engine foward. But they do work great and are hard to break. They work better on twin engines than single engine boats but still work nice
with thier bravo conversion kit the engien stays put the tranny sits in the extension box so you don;t have to remount your engine. Direct bravo replacement.
Pretty slick looking setup. |
That makes it even better I havn't seen that set up yet all their asd models are available that way now? If so thats Great! I have to get my head out of the engine hatch more often and see whats around.
1 Attachment(s)
:D
| All times are GMT -5. The time now is 08:01 PM. |
