-   -   502 Spark Plugs (https://www.offshoreonly.com/forums/general-q/65400-502-spark-plugs.html)
Steel Outlawed 12-04-2003 07:07 PM
502 Spark Plugs
What spark plugs are you guys running in a relatively stock 502. I do have a MSD box and Lightning Headers.
deboatmon 12-05-2003 06:19 AM
SPARKPLUGS
I run NGK BR6FS.
NGK seems to be the plug of choice for many these days.
baja27 12-05-2003 09:35 AM
I have been using AC Rapid fire 1, the plugs are expensive but forth it, why you ask? It will clean up your transom. The plug extends deeper into the combustion chamber. Also you will be able to use them for two seasons.
splashandburn 12-05-2003 10:10 AM
What plugs are you using in the HP500EFI's?
Shooter 12-05-2003 02:46 PM
save your money run AC R43TS
US1 Fountain 12-05-2003 04:35 PM
I installed the rapid fires this spring on my 502's because of the postive posts for them. My transom is always black. I will replace them with the Merc spec'd AC plugs when the time comes.
Shooter 12-06-2003 06:21 AM
if you read Dennis Moore's book you will realize that what makes all thee plugs similar are the extended tips, I have used the AC R43TS on all my boats 454, 454 w/blower, now 502s and never get any black crap.
They are much cheaper than the "novelty" plugs too and do the same job.
FloridianSon 12-07-2003 12:23 PM
Shooter what about page 177 Champion RV15YC4 EX.long projected nose or AC #R43LTSM
Shooter 12-07-2003 03:10 PM
I think the LTSM is a different size plug, where the 43TS just has a long tip. No sure though. Always used the AC myself.
