-   -   Welding Cast Iron (https://www.offshoreonly.com/forums/general-q/65670-welding-cast-iron.html)
HOUSTONPROP 12-08-2003 10:07 AM
Welding Cast Iron
We have welded several pickups for monster trucks ,usually tig, and stainless.
but if the piece is cast iron the best rod to use on /A/C CURRENT Tig welding procedure is>> a-2 welding rod. which is aluminum/nickle bronze and we have welded several of the Mercruiser exhaust manifolds or anything made of cast iron.
Iggy 12-08-2003 11:21 AM
I've welded CI by DC (I think) stick. Can't remember what rod I used (too many years ago), but I do remember that it was a special rod.
I know you should preheat the material to several hundred degrees prior to welding to prevent thermal shock. Then stopping every so often to reheat the material and allow a slow cool down at completion.
CI gets very brittle during the welding process. If not done correctly it will fracture along side of the welded area.
Sounds like you've got a good welder working for you.
Good job.
cougarman 12-08-2003 11:31 AM
Cast Iron
I believe preheat and weld with nickle Rod.
Iggy 12-08-2003 01:43 PM
CougarMan I think you're right.
The use of a nickle rod sounds familiar.
Thanks for jogging the memory.
HOUSTONPROP 12-08-2003 03:09 PM
nickle/aluminum a-2 welding rod
