-   -   Single Engine 33 Footer (https://www.offshoreonly.com/forums/general-q/65834-single-engine-33-footer.html)
turbineboat 12-09-2003 07:05 PM
What do you guys think about an '88 Fountain 10 meter with a single 1200hp engine? I know docking would be compromised but what about top end and handling. Speed ?
Merc #6 or Arneson? ... I've heard Fountains run level, so the Arneson might push the bow down a bit much, anyone ever use those Arneson rocker plates on a big V hull with no steps? Let me hear what you think about this... I have the boat and I have a 1200 hp turbine engine I want to install in her, but I don't want to build something that will only do 75 mph... Anyone know the weight of that hull?
Thanks ,Eric
Geo 100 12-09-2003 08:19 PM
About 15 yrs ago, Arneson had a 32-36' with a T55
turbine and it did about double that. Don't know the hull make but it only had 2 seats controls engine and fuel
tanks.
Sounds like you will have a cool project, plus you can roast hotdogs on the fly.
GLH 12-09-2003 08:23 PM
Originally posted by Geo 100
...a T55 turbine and it did about double that. ...it only had 2 seats controls engine and fuel tanks.
Controls? what flaps, tail rudder and elevators! :D
formula31 12-10-2003 07:17 AM
Somewhere I remember seeing an article about a boat Arneson put together with a single just like that with a shaft drive. Did over 200 mph. Dont know what ever happened with that project.
Gary Anderson 12-10-2003 09:02 AM
There was a british company (Liberty Turbine) that rigged a boat that size with a T55? connected to a splitterbox and 2 Bravo drives. How about that for an option?
Gary
Geo 100 12-10-2003 09:11 AM
There was a test race on the Colombia river to see what
the waters were like. About 30 boats showed, one being
Arneson's. When the race was started they went up river 25 miles and back. If i remember right it the Arneson boat was gone for 22 min. and the next boat to arrive was 30 min later.
Cord 12-10-2003 09:45 AM
Arneson would be an excellent candidate to answer your questions. They've done several turbine boats in the past. Also consider talking to Fountain. I'd be interested in the change of cg.
turbineboat 12-10-2003 05:35 PM
I am more concerned with how a big V hull will do with one drive????? any help???
puder 12-10-2003 07:31 PM
well superboat makes a 30' with a single engine and drive. But its much narrower than a fountain.
Aggressor 25 12-11-2003 07:25 AM
There are a handfull of single engine 32 Sunsations ou there. My good friend has a 2003 500efi with ITS box that does 72 to 75 and he is adding a 3.3 Whipple this winter which should see high 80s. With 1200 HP turbine you have the power. I just dont know about the best drive to most efficiently make use of it.
