-   -   Gen 6 to Mark IV.......? (https://www.offshoreonly.com/forums/general-q/65860-gen-6-mark-iv.html)
DonMan1 12-09-2003 10:31 PM
My 1998 454 is trashed.
For economic reasons, I want to swap in an older big block. EXACTLY what is needed to go from a Gen 6 to Gen 4? I am using a Bravo drive.
Will my L29 heads work on the older block?
Thanks for your input.
RedDog382 12-10-2003 12:22 AM
I have (2) Mark IV flywheels and starters if you need them for your conversion. Also have new fluiddamper, roller rockers and lifters. I think I still have a 454 Mag fuel pump too. Repost or PM me if you are interested.
Big Dawg 12-10-2003 11:23 AM
Hey Red Dog, I might be interested in your stuff How much are you looking for for these items?
ursus 12-10-2003 11:43 AM
The holes in the alternator bracket may not line up, depends on which heads you end up with the gen 6 brackets use 7/16 bolts in slightly different location then the 3/8 bolts used in MK IV, You can usually drill an offset hole with a drill press in the bracket.
The MK IV sea water pump pully doesn't stick out as far as the Gen 6 by about 1/8-3/16 " so when going from a Mk IV to gen 6 you have to shim the bracket to get the pullies to line up , you are going the other way so this is a problem you may need the mk IV pump
The electric fule pump will work but you will need a block off plate for the fuel pump boss.
The remote oil filter ( the part that connects to the block where an oil filter normally goes) is different you will need one from a MK IV
Flywheel and balancer are different you will need MK IV, the starter motor is ok
jpclear 12-10-2003 07:53 PM
I read somewhere about head compatibility when swapping blocks that way... core openings and such. I think it was well covered in Dennis Moore's BB Chevy Marine book. Check it out if you can get your hands on a copy, or I'll dig mine out if you can't. --- Jer
RedDog382 12-11-2003 06:10 AM
Big Dawg,
PM or call me @ 419-882-1680 with items you are looking for. I have numerous other items for Mark IV. Leave call back # or fax if you get my voicemail.
Thanks!
