-   -   fuel delivery problem-regulators (https://www.offshoreonly.com/forums/general-q/66207-fuel-delivery-problem-regulators.html)
timucin 12-13-2003 11:46 PM
will use holley 12-705-1 160gph electric fuel pump to feed two 850 cfm double pumper carbs on blower.
now i need a regulator which has;
one input and two outputs .
outputs have to be adjustable cause i want to have 8psi(hot) on each carb at idle.
my questions are:
-is this pump enough for this application?
-what regulator do i have to use? any brand and part number help would be perfect
thnx
Griff 12-14-2003 02:37 PM
You should be able to run a fuel distribution block off of the regulator. I don't know about the fuel volume though.
Griff 12-14-2003 03:11 PM
BTW, Every Holley regulator I have seen has 1 input and 2 outputs. Most are 1/2inch inputs with 3/8 inch outs. You my need more volume though.
Mallory does make a 1 IN and 4 OUT regulator that is adjustable from 4-12lbs and has larger IN's and OUT's.
Summit part # is MAA-4200.
If you use this, you can just run fuel lines to each bowl on the carb.
Aeromotive and Barry Grant also makes several designs with various configurations.
timucin 12-14-2003 06:05 PM
thnx too much
