-   -   transom assembly installation (https://www.offshoreonly.com/forums/general-q/6657-transom-assembly-installation.html)
formula31 01-24-2002 08:40 PM
Im assuming I can use some gm weatherstrip adhesive to hold the big o-ring seal on the gimbal housing while installing. Does this sound OK? Also, should I use any additional sealer/bedding compound? Oh, Bravo 1 transom assembly.
[ 01-24-2002: Message edited by: formula31 ]
FBRONCO 01-25-2002 08:23 AM
I used the glue/sealer used to install the drive shaft and shift bellows from Mercury Marine.
Scarab28 01-27-2002 05:32 PM
I did the same as 24Outlaw. Worked fine.
formula31 01-27-2002 07:03 PM
Yea, I shoulda too. The weatherstrip adhesive was a pain. Stripped the paint right off the groove area. All done now but next time I will use the bellows adhesive too. Thanks guys.
