prop cupping?
What is the benefit of prop cupping?
prop cupping
cupping of a propeller allows the operator to trim the outdrive at a higher angle holding the prop,and lifting the bow of the boat it also can reduce the rpm by 250 rpm or so it depends where you put it and how much,
it helps hold in sharp turns ,reduces cavation?spelling,or slip. it can make the boat plane out quicker. But the main thing is it creates lift and reduces drag by getting the boat up and higher out of the water for increased speeds. hope this helped I tried to put it as simple as I could. :rolleyes: :D |
Thanks for the info-Im going to send you some pics of my damaged props to see if you can do anything with them.
Thanks |
jryan
if the complete blade is not missing ,more than likely they can be fixed,pictures are nice though.
[email protected] |
1 Attachment(s)
heres a pic of the damage
1 Attachment(s)
and the cupping
1 Attachment(s)
2
and run like new
1 Attachment(s)
NO PROBLEM,WE CAN MAKE IT LOOK LIKE NEW,Darin
| All times are GMT -5. The time now is 03:02 PM. |
