Cam upgrade
Please help me select a cam!
Sonic 35ss. 461 cui. 9.5:1 compression ratio rectangular port heads 990 weiand team G (looks like stealth) dual plane Holley 850 Gil exhaust (silent choise). Prefere hydraulic flat tappered (not roller lifters). Takes a long time to look at all available cams (crane, comp, isky, ...), give me a shortcut! /Goran:confused: |
I'm no cam expert, but I do know that the short riser Gil Magnum Choice exhaust will hold you back (I have the same exhaust). The exhaust flows fine, but I think those risers can only accept very minimal cam overlap (if any), so your duration and LSA choices are going to be limited. If you run a Crane 168731, you would need to have it ground with a 112 or 114 LSA. You might get by with a 168721, but I think that's a significant drop in power from the 731. That said, you should still be able to make a lot of power.
Anyway, as I said, I'm certainly not a cam expert. So I'm very interested to hear what the smarter guys have to say. |
Two good hydraulic flat tap cams are the crane cam found in Merc's 370,400,420,425,525... and Edelbrock's torquer cam. I don't have part numbers for you, but they can be found easily on their web-sights.
Both have 114 LSA so the overlap is minimal; there won't be any problems with your exhaust. |
Erson JB 100 on a 112+4
Specs are 228/235 @ .050" with .540" lift. I have used this cam on a couple of motors very similar to yours and it works great. Prop for 5200 to 5500 max. No reversion with stock manifolds! Very good power from 2500 to 5500. :) |
I use the Edelbrock torker cam for very similar engines with good success. I have the same exhaust. That cam is 224, 232, .527, .553 on a 114 seperation.
I have 2 hp420 cam's and lifters in perfect cond., if interested
JMPH |
Does someone know the Crane part number for Merc's 370,400,420,425,525 cam?
Thanks! Goran |
Goran,
Merc # 451-7892 Crane Part #132561. Here is the spec card for that cam. http://dab7.cranecams.com/SpecCard/D...1=Display+Card Bob |
JMPH, please let me know the price?
photos? /Goran |
Thanks Bob!
| All times are GMT -5. The time now is 03:47 PM. |
