Scanning a HP500EFI
What kind of data is available when you "Scan" a HP500 EFI with Mercury's scan tool? Will the scan tool show overheat condition, overrev, hours of operation @ WOT, etc?
Thanks, Dean |
See http://www.rinda.com/marine/marine.htm
This is the tool for reading the ECU, This does not tell you everything but it gives you an Idea. The HP500 Uses the MEFI3 ECU. I cant remember them all but here are a few: Hours Volts RPM Coolant temp any ECU flags set IAC position Throttle position Knock sensor Manifold vac pressure there are a few others I cannot remember The rpm hours is logged in the ignition module you would need the adapter to read these. |
Ray,
Thanks for the info. Dean |
once you plug into and communicate with the ecu-it will give you engine hours-run time -run time 1000-2000 rpms,2000-3000 and so on up the scale to rev limiter -these parameters can be found in the service mode or gen specs-i use a laptop computer to scan mine but its all in there with your scan tool.
To my knowledge you cannot get stored rpm info on the hp500efi with a rinda scan tool. I have the tool with the latest software update and cannot access that info. You can get that info with Thunderbolt V ignition and PCM 555 and PCM 038. Somebody correct me if I am wrong.
| All times are GMT -5. The time now is 01:17 PM. |
