-   -   GM 3 valve head photo (https://www.offshoreonly.com/forums/general-q/67464-gm-3-valve-head-photo.html)
rmbuilder 12-30-2003 01:13 PM
GM s new 3 v heads
http://www.ls1tech.com/forums/attach...achmentid=1381
http://www.ls1tech.com/forums/attach...achmentid=1382
Bob
Cord 12-30-2003 02:12 PM
What's that on?
JaayTeee 12-30-2003 02:53 PM
You might have to be a
"rocket scientist" to figure
out the ex. valve lift, with
those bell cranks and extra pushrods
involved:rolleyes: :D :D
jt
Back4More 12-30-2003 03:25 PM
as quire as a 3 dollar bill...
jspeeddemon 12-30-2003 07:31 PM
Looks as messed up as a football bat! Surely all the R&D GM has to spend on the advancement of the next generation powerplant, they can do better than this. Look at the return on investment on the LS1 family GM has now derived in their trucks after developing this series first for their corvette powerplant.
Reed Jensen 12-30-2003 07:53 PM
I'd like to see how the intake valves are adjusted. There must be an adjust under each valve. What I can't understand is why domestic manufacturers have resisted for so long going to overhead camshafts.... ?!
paradigm shift 12-30-2003 08:12 PM
Yep then NASCAR. Just think a BBC with overhhead cam!!. Or 904 ci 4 valve dual overhead cam!
http://www.schubeckracing.com/index2.html
Reed Jensen 12-30-2003 09:20 PM
I've seen the schubeck engine before... but it's a limited production unit that I'm sure parts are waaaaay expensive. What ever happened to the Falcon engine that was supposed to hold so much promise. After all.... they had a patent on the thing. Ever been to the USPTO site and seen some of the bull**** things that are awarded patents? It just seems weird that so many domestic builders are still pushrod. Not that pushrods are bad.....
paradigm shift 12-30-2003 10:08 PM
Shubeck is limited production for sure. Falcon? Not to get to far off the topic. Multi valve and overhead cam is the future. Don't know about GM 3 valve rocker set up? Is this skunks works or what is it run in?
tomcat 12-30-2003 10:20 PM
1 Attachment(s)
Hot Rod - June 1999
Jim Feuling's first prototype for a three valve head, two intakes, one exhaust, centrally located spark plug. Never heard about it again, but the idea was better breathing without insane valve train specs, and avoidance of hot spots and resulting detonation caused by the difficulty of cooling between the two exhaust ports. Very smart guy, worked on the Aerotech porject for Oldsmobile, many other manufacturers.
