-   -   Latham Marine info needed (https://www.offshoreonly.com/forums/general-q/68129-latham-marine-info-needed.html)
pachangalpina 01-07-2004 08:19 AM
I am looking for some parts to complete a full hyd steering setup. I have called Latham several times over the past couple of months to request a catalog with no success. So I hope that somebody here may be able to help. Does anyone have a parts list for the twin external components and a parts list for the full hyd system? Or, does anyone know how to get a catalog?
Thanks, Todd
klaw 01-07-2004 10:12 AM
just contact alfster or Maxx on the board they can help you out
pachangalpina 01-07-2004 11:17 AM
Thanks, but I believe that some of the parts that I need are going to be specific to the Latham system. The parts were removed from another boat and some of the mounting hardware is missing. The main thing that I need for the external system are the bolts that mount the rams to the drive caps. Also need the bulkhead fittings to connect the external lines to the internal system.
Todd
plumbers crack 01-07-2004 06:17 PM
latham steering
I have same problem need the odd shaped bolts that connect drive caps to tie bar and pistons.Can these be purchased anywhere?
MIAMIBOYZ 01-08-2004 12:16 PM
CALL LATHAM MARINE,THEY HAVE ALL YOU NEED
