-   -   exhaust question please help (https://www.offshoreonly.com/forums/general-q/69706-exhaust-question-please-help.html)
H2Xmark 01-21-2004 08:21 PM
hey guys, well I am adding EMI thunder manifolds with the short stainless risers to my boat, it has the corsa capt call exhaust, my problem is when I pulled my silent choice pipe and looked down the Y pipe for the through prop, the flapper in the Y pipe [through prop] is damaged, I looked at Bam's site to see if he had them [no] ,so I need a part number are info on where to pick these parts up at . thanks
Mark R
they are the newer style 2 piece flapper if that helps
Liberator21 01-21-2004 08:44 PM
You're in luck! I know nothing about that, BUT the March issue of Family and Performance Boating is out and they had the same issue while doing an exhaust upgrade. The part number they have in the article is for the 2 piece flapper. Part number is 807166A. (Mercury Marine). Hope this helps.
Paul
H2Xmark 01-21-2004 09:38 PM
hey thanks a million, I will check out the part number, I could not find a number for this on BAM's site are by a search here, thanks again
Mark
Offshore Addiction 01-22-2004 06:45 AM
I have them!
H2Xmark 01-22-2004 05:56 PM
hey, in stock cool, are they aftermarket are mercury? i will check out your web page thanks
Mark
