-   -   Prop blowout. Any sugestions (https://www.offshoreonly.com/forums/general-q/69820-prop-blowout-any-sugestions.html)
force 320 01-22-2004 10:45 PM
Ok I made my first run today in my older boat project, and am fairly new to this boat ,its a 32 baja, 496 ho, trs, bravo 1, 4 blade 26 p. problem is on take off drives down, if I go any faster than 4 sec. idle to full , the props blow out, same thing in a full throttle turn, slight up drive. Dose the drive angle (toe in - toe out) have any thing to do with this, or altitude ( I am at 5,400 elevation) any help would be greatly appreciated, Thanks.
HOUSTONPROP 01-23-2004 01:04 AM
force320
it all has to do with set up ,conditions and the props as well,
give me a call and we can TALK PROPS AND ALL your concerns.
we can get you dialed in ,will be more than glad to help ,
Thanks Darin:)
throttleup 01-23-2004 06:58 AM
Are your props lab finished? Sounds like they are. If so you are right about where you should be for a top end set-up. Did you raise the X dimension of the out-drive? I would be surprised if you could blow-out a stock Bravo 1 with TRS drives at a normal drive height.
Try some toe-in. Start with 1/8" toe-in and see if you notice a difference, especially in turns.
Do the props blow-out in high speed turns at WOT or only at low speeds?
Matt
Cord 01-23-2004 09:03 AM
Altitude will definetly have something to do with it. If you don't have a diffuser ring on your props, adding one will help. So will adding some cup near the root of the blade.
HOUSTONPROP 01-23-2004 11:09 AM
cord
1 Attachment(s)
we are hiring :D you the man!!!!!!!!!!;) and add a little on the tips.
KBUSH1 01-23-2004 12:59 PM
hey darin sent you a private message about prop work. let me know...
force 320 01-23-2004 01:01 PM
these are brand new bravo 1 solid hubs. the trs drives are in stock location, I dont know much about x dem. and what is a defuser ring.( ai know ..beginer), the drives are set at 0 toe ( strait ahead).
Cord 01-23-2004 01:16 PM
Now that's real interesting. Bravo 1's are amoung the best (if not the best) planing prop out there. It will have a diffuser ring built in. My thinking is that you have some other issue...
force 320 01-23-2004 02:05 PM
how about switching drives and turn props in.
Havasu Cig 01-23-2004 02:48 PM
I had a 26' cat with a high x, and ran into the same problem running a labbed 32 4 blade. We added some cup to the prop and it helped.
I eventually went to a 1.35 gear ration and dropped a couple inches in pitch. That was a cure to the problem, but lost some mid range acceleration.
I would try adding a little cup, it might be your cure.
