Herring Props?`
Can I run aset of 5 Blade Herrings 30P
on my 2001 Tiger T/S Xr's with 680 HP? I'm getting low 90's with bravo 32P non Labbed (5400 RPMS) |
i was totally impressed with herring props. WAY nicer than any merc for bravo i've sen.
performed better too. |
Your rpm should be very close between the 30 Hering and the Bravo 1 32. Herring is true-to-pitch while the Bravo 32 is really about a 30.5" pitch. Add the 5th blade and you should be real close.
I agree puder. The Herings are the finest out-of-the-box props I have seen. I would be wary of purchasing used Herings, however. Matt |
I have a pair of race labbed Bravo 34 4 blades from Zipp Express for sale. Test time only on Zipp and one hour on my Spectre. Let me know if you are interested.
shawn |
Do you think the Herrings will increase the top end?
Wet-Kitty,
That is the $4000.00 question. We have been working with Hydromotive through the fall and winter on a prop that would compete with the Hering 5 and 6 blade. I just finished the first set of prototype props. The are a full 15.5" diameter 5 blade propeller with a 31" pitch. If you like give us a call and I can fill you in on all the details. We also have this prop as a test prop in 31 and 32 pitch. Matt 877 842 6855 |
1 Attachment(s)
This is the prop I was reffering to. I will have some data on it tomorrow after we test it on the Donzi Super V race boat sometime tomorrow.
This is not a P5. It is a Hydromotive prototype prop that is very different than anything else Hydromotive has. Matt |
The 5 blade herrings are on my brothers new 36 Apache.
I was going to try them out first & see how they worked. I'll give you a call Fred |
how did the test go? i may be intrested.
Won't know until Miami. Just Got back from Texas. Jimmy bought an Apache.
I heard the Herring 5 bladers will help the midrange acceleration, BUT KNOCKS A FEW mph'S OFF OF THE TOP END. i WILL LET YOU KNOW. Fred |
I tried a 5 blade hering on my 27' fountain. It was slower accelerating no more top end but it sure looked nice. I raised the prop shaft level with the bottom of the boat looking for some speed. I believe I would have seen an increase if I had a stepped bottom.
| All times are GMT -5. The time now is 09:20 PM. |
