Plumbing intercoolers? No pump?
It has been suggested by a couple engine builders to plumb the intercoolers directly to a transom mount pickup and then out the dump. No pump only a screen in between.
Has anyone done this? Should it be done on a pleasure boat? I would think the lack of water at idle would be a problem when trying to get on plane. Not that I hammer it but at 3500 the boost does just start to build. I am wondering what speed does this setup start to provide enough water. I know there are many variables but I am looking for some general direction. This all stems from my whipple setup and the intercooler robbing water from the pipes. I was intending to put a dual or tripple seawater pump but then was told to go without??? I was told not to put in a restrictor in the cooler line. Any Ideas or experiences would be great. |
This is correct. Just plumb it directly into a transom pick up. You'd be amazed how much water it will get. Set the pick almost level with the bottom on a conventional, and maybe a little deeper with a step hull. You should check out the adjustable pick ups from CP Performance.
Steve |
My boat had separate pick-ups for the intercoolers when it was equipped with turbos.... I'd suggest that you have a sea strainer and a screen or the intercooler will fill with crap. Mine did... Don't worry about not having enough flow... if you get the adjustable pick-ups ... you will get lots more than needed.
Or get one of these scroll down to the bottom of the page
I have mine set up that way. No problem. Totalmp has it right.
Ray,
My Whipple setup takes the intercooler water from a T just after the sea pump. The intercooler outlet goes thru the transom to a braided hose connected to an Innovative Marine shower. I'm running a Gaffrig sea strainer plumbed in before the sea pump also. No problems with lack of water to the pipes (CMI's). This setup lowered my 30 psi water pressure to 20-22 psi. Dustin gave it his blessing as well. |
My cat was plumbed that way. Pick-up on the bottom, and dumps out the transom over the drive. It actually acted as a drive shower while running. I was running a strainer in between as well.
I plumb them, from a pickup toward the rear of a sponson on tunnels and transom on everything else.
Pickup to sea strainer with relief valve to intercooler to oil cooler to transom dump. This keeps fuel puddling to a minimum at idle and lets the oil get up to temp. It starts flowing a soon as the boat is on plane. |
Ray, do not let the cooler core go dry. The transom pickup is OK, but we also run a #4 or #6 line from the sea water pump to the cooler, this pisses just a small amount of water to it at all times. If the core is dry a backfire with flame in the intake can melt the core.
Ray I run mine the same way. except that I use my out drive pickup to supply my inter cooler, and I use a
1 1/4" thru transom for my engine. Dustin Whipple had me do it this way 3 seasons ago, and I have had no problems ever sense:p |
I have mine tee'd off the main water line coming off the drive with a 5# pop off valve to prevent fuel puddling at low speed.
| All times are GMT -5. The time now is 04:49 AM. |
