-   -   Scarab I Deck Hatch (https://www.offshoreonly.com/forums/general-q/70873-scarab-i-deck-hatch.html)
sid 02-03-2004 09:43 PM
Scarab I Deck Hatch
I am looking for any and all advice on installing a deck hatch on my 1985 21 Scarab I. The boat is in excellent original condition. However, I believe the cabin would benefit greatly from the increased sunlight and ventilation afforded by a hatch. More specifically, would a centerline hatch diminish the structural integrity of the boat? Moreover the deck at the centerline is not flat. Please advise.
homan 02-03-2004 10:03 PM
1 Attachment(s)
why not a small one on each side
Vmax 02-04-2004 11:24 AM
I had a friend with a 1986 scarab I with a center mounted deck hatch. His came like that from the factory. It was wide enough to drop straight down through with an adult sized body. If I remeber it was still very tight in there and had a built in cooler in the center so you had no step down for cabin ingress and egress from cockpit.
Iggy 02-04-2004 11:43 AM
Insted of one on center, how about two smaller hatches? One on each side.
My Formula offered two small hatches as an option on my F-206. The wood backing frames were glassed in under the deck during construction but I don't have hatches installed.
Gary Anderson 02-04-2004 12:54 PM
THe bigger scarabs reinforce the coring with plywood around the hatch cutouts. You may end up with a lot of cracks in your deck if it's not strong enough.
Gary
sid 02-04-2004 10:03 PM
Thanks for the advice. I like Homan and Iggy's suggestion of two small hatches. At this point, i will probably install two 10 X 10 Bomar Hatchs. That should give plenty of ventilation and sunlight. However I am still concerned about stress cracks. Even though the boat is almost twenty years old there are no cracks on the deck now.
