New motor --- need help from the pros
I plan on building a new 540 Whipple charged motor for my 25 Daytona and would like advice on crank / rod selection. I expect to run race gas and build 900-950hp. 9:1 compression / 10# boost. I realize that I can just select top of the line parts without worries, however I don't necessarily want to overkill the the internals if I do not have to. BTW, I will be selling my complete long block HP500EFI (Pan to flame arrestor (no accessories or exhaust) if anyone has interest.
Choices are: 1. eagle/eagle 2. callies/manley 3. crower/crower billet 4. other??? Here are the components that I have selected so far: Super Charger - 3.3 liter intercooled EFI Whipple Block - Dart Big M w/ billet caps Heads - AFR 335/121 CNC port CAM - Crane 651 Pistons - JE flat top Oil Pump - Moroso pro billet Thanks in advance |
Hard to overkill internals @ 950 HP
Moldex/Bryant.../Carrillo Bob |
If you are buying the blower from Dustin, I betcha he could pick all the parts for you. For this motor, I would not be using any eagle parts. Also, do a search under the tech section for a thread on the new AFR heads. It was very interesting.
CAllies/carillo/ J and E/ Manley Stainless intake Inconel exhaust... good stuff.
I would not use the Moroso Billet oil pump. The small screws that hold on the pick-up are a weak point. My pick up cracked and I threw the Moroso pump out.
| All times are GMT -5. The time now is 03:13 PM. |
